Aftermarket Wheel & Tire Fitment Chart
ROGUEPLANET
Car: 2012 Nissan Rogue se
Ok, I see alot of views on this topic, but no post lately.
I should have read this before i ordered my wheels and tires.
I am going from stock 16's to 18's, 235 55 18's.
SO, what kind of issues am i walking into here? I see im in the red by eggnogs chart.
My wheels wont be in until July, and they ordered my tires as well, should i go back in and tell them i need to change it to 225 55 18's to be on the safe side???
What would you do?
ROGUEPLANET
:ohno:
ROGUEPLANET
So discounttire said my wheels wont be in for another 2 months. WTS. I stuck to the 235 55 18's.
EddNog
Car: 2008 Nissan Rogue SL AWD
ROGUEPLANET wrote:Ok, I see alot of views on this topic, but no post lately.
What would you do?
It's not terrible, but your speedometer will read lower than it should.
What offset are the new wheels?
-Ed
JMed
Car: '08 Nissan Rogue S AWD Pearl White
'15 Nissan Rogue SV Black
Does anyone know if these will fit a Rogue?
Factory Original Altima
Those wheels have an Offset of 45mm.
If they fit and I decide to go for it, I might get some 225/55-18 tires.
ROGUEPLANET
What would you do?
Sorry, I totally missed you replying to this.
I dont know for sure because my receipt is at work, but im pretty sure its +44mm Like this says.
-Ed
JMed
I guess the 18" 45mm I posted before should fit, because those you posted are +45mm :rolleyes:
I'm still looking around and trying to decide between 18" with 225/55R18 or 19" with 225/50R19. Anyways, any of those sizes won't make any noticeable impact on my speedometer.
tdhk
Car: '11 Rogue S awd K51 stock
Would +50mm offset be okay? I'm really liking the newer maxima rims in 19"
idelgado782
Car: Nissan Rogue 2011
Hey guys. I'm looking to replace my steelies on the rogue with some rims. I'm not sure what size I should go with. I'm considering keeping the tires I have now, they are new pretty much no tread wear. Or getting wheels and tires package either 17 or 18. Here is where my reservation comes to play. I live in Northern NJ and there are tons of potholes in my area. I had 18s on my Acura TSX and constantly had cracked or bent rims. I know that its because there wasn't enough tire to absorb the pothole, and I'm not sure if I would have the same problem with the suv now? :confused: :confused: That is why i'm considering staying with the 16" tires and just having them put on the new wheels. What do you guys suggest? Thanks in advance!! :sad:
EddNog
idelgado782 wrote:Hey guys. I'm looking to replace my steelies on the rogue with some rims. I'm not sure what size I should go with. I'm considering keeping the tires I have now, they are new pretty much no tread wear. Or getting wheels and tires package either 17 or 18. Here is where my reservation comes to play. I live in Northern NJ and there are tons of potholes in my area. I had 18s on my Acura TSX and constantly had cracked or bent rims. I know that its because there wasn't enough tire to absorb the pothole, and I'm not sure if I would have the same problem with the suv now? :confused: :confused: That is why i'm considering staying with the 16" tires and just having them put on the new wheels. What do you guys suggest? Thanks in advance!! :sad:
I had 20" wheels and was lowered on sport springs for a while and lived in NYC and never had a problem, so I'd say even 18" has little to no chance of bent or damaged rims without suspension damage (in which case you have other problems) and NYC roads are no better, if not possibly worse than Northern Jersey roads. That being said, I downgraded to 18" rims and swapped the stock springs back to recover a lot of lost ride comfort at the expense of only some handling prowess.
-Ed
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
-Ed
I'm on my second Rogue, and both came equipped with 18" wheels. No worries! :yesnod
idelgado782
Ok guys. Thank you so much. I figured it wouldn't be too much of a problem because I know there more expensive rogues come with stock 18s as Rogue One just said. I really like these. The first & second ones are my fav. And the more I look at the second ones the more I really like those. Which ones do you guys think? I might be getting them in the next few weeks. Thanks so much again for helping answering my ?'s
I also really like the drifz but from what i've read some sites say they don't fit the rogue and some say they do? How would I be able to verify? If they would fit, I would like to get them in all black. If that's not possible, I was thinking about plastidipping the emblems and grill red. What are your thoughts?
Thanks again guys! :wavey:
EddNog
idelgado782 wrote:Ok guys. Thank you so much. I figured it wouldn't be too much of a problem because I know there more expensive rogues come with stock 18s as Rogue One just said. I really like these. The first & second ones are my fav. And the more I look at the second ones the more I really like those. Which ones do you guys think? I might be getting them in the next few weeks. Thanks so much again for helping answering my ?'s
At the end of the day it should really reflect your personal taste, but my wheels look exactly like the silver version of your second choice from the top (I have silver 18-inch Elbrus IO6 wheels on my blue Rogue).
What color is yours?
-Ed
rdub2k4
Car: 2012 Nissan Rogue SE
2011 Mitsubishi Lancer GTS
Idk if this is a stupid question or not, but I'm looking at picking up some 2005 Infiniti G35 wheels for the Rogue. 18x7.5 +30 66.1 hub. 5x114.3 bolt pattern. So it should fit like a glove and be flush w/ the fenders. My question is tires... Looked up on tirebuyer and they recommend $160 tires. Do we have to use SUV/Truck tires on the rogue at 225/55 or can I use some Nexans? $110 compared to $160 is huge per tire. Thanks guys.
EddNog
rdub2k4 wrote:Idk if this is a stupid question or not, but I'm looking at picking up some 2005 Infiniti G35 wheels for the Rogue. 18x7.5 +30 66.1 hub. 5x114.3 bolt pattern. So it should fit like a glove and be flush w/ the fenders. My question is tires... Looked up on tirebuyer and they recommend $160 tires. Do we have to use SUV/Truck tires on the rogue at 225/55 or can I use some Nexans? $110 compared to $160 is huge per tire. Thanks guys.
Any tires you want of any classification, as long as they are the right size, will work just fine.
That being said, it's important to use the right tires for the right job. Don't get summer tires if you live in an area that gets down to freezing temperatures and/or gets snow if you don't plan to swap in and use a separate set of all-season or winter-specific tires during the cold season. Summer tires will be great in warmer climate areas and for 3 seasons in the snow belt, but never drive with summer tires in the winter.
-Ed
rdub2k4
Thank you sir. Being in Texas, summer tires work fine year round. Rarely ever snows. I have Nitto Neo-Gens on my Lancer and they hold up just fine.
Now the wheels sold.... time to find some more G wheels. :) Sedan wheels, not the staggered coup wheels.
kencyr1
Car: 2011 Nissan Rogue pearl white
Any problems with putting 20"rims on a 2011 rogue?
JMed
kencyr1 wrote:Any problems with putting 20"rims on a 2011 rogue?
You can read this post by EddNog...
EddNog wrote:I had 20" wheels and was lowered on sport springs for a while and lived in NYC and never had a problem, so I'd say even 18" has little to no chance of bent or damaged rims without suspension damage (in which case you have other problems) and NYC roads are no better, if not possibly worse than Northern Jersey roads. That being said, I downgraded to 18" rims and swapped the stock springs back to recover a lot of lost ride comfort at the expense of only some handling prowess.
-Ed
So kencyr1, basically you can put 20" on your Rogue without a problem but the bigger the rims are, the tire profile will be lower and this will make the ride somewhat rougher...
rdub2k4
I have a fun predicament right now.
I scored some 18x9.5 + 30 offset wheels for the Lancer this past weekend. Amazing deal. Gonna be running 225/40's stretched across em.
If I don't like em, I may toss it on the Rogue. Judging by the chart, I'd need some 245/50's to be the "correct" size, am I right?
Wonder if I would run into any issues with a 9.5" wheel on the Rogue... that's BMW status right there.
Instagrammed picture of the wheels ;)
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
i have g37 rims if anyone is interested
idelgado782
Hey guys, here's an update! I stood with the Stock 16" tires that my Rogue came with ( I was being a bit cheap honestly, & don't know how long I'll really stay with it ) so I ended up getting Motegi MR 107's. Check it out let me Know what you think!!
bigrobsw
Car: 2010 Nissan Rogue
I have a 2010 AWD will a 20" Wheel with 45+offset fit fine? will I have any problems?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
The offset is only meaningful if you know the width of the wheel. What is the width of the 20" wheels?
bigrobsw
itsa300zx wrote:The offset is only meaningful if you know the width of the wheel. What is the width of the 20" wheels?
The width of the wheels are 8.5
RNsteve
Car: 2010 Nissan Rogue sl
I have my first ride,a Nissan Rogue 2010 SL with tire size 225/60/17. Trying to shop around and find a solid deal on a set of steel rims/winter tires and I found a solid get 4 motomaster 215/70R16 100S TT winter tires with steel rims fpr $250.
According to the size/fit calculator i've used, it should be a good to go, but just wanted some second opinions.
Thanks.
http://www.1010tires.com/Tools/Tire-Siz ... /215-70R16
Rogue One
2022 Honda Pilot SE
RNsteve wrote:I have my first ride,a Nissan Rogue 2010 SL with tire size 225/60/17. Trying to shop around and find a solid deal on a set of steel rims/winter tires and I found a solid get 4 motomaster 215/70R16 100S TT winter tires with steel rims fpr $250.
Thanks.
We have an incredible SEARCH feature on this forum. Merged with existing thread.
--------> READ BEFORE CREATING NEW THREAD! <--------
spearfishman
Car: 2016 Rogue SL
Hi everybody, does anyone know if it's possible to use a 16" rim from an older Rogue on a new 2016 Rogue SL? Our car currently has the 225/60R18 tire on it. But we are looking for a set of rims for winter tires.
A google search seems to indicate that only 17" & 18" rims are allowed.
According to this website here: http://www.wheel-size.com/size/nissan/rogue/2016/
Wheel General Info
The ranges of possible values for tires and rims for a Nissan Rogue 2016
Tires for Nissan Rogue 2016
Diameters: 17.0'' - 18.0''
Width (mm): 225 - 225
Tire aspect ratio (%): 60 - 65
Smallest tire size: 225/65R17 102H
Largest tire size: 225/60R18 100H
Rims for Nissan Rogue 2016
Bolt pattern 5x114.3
Diameter: 17.0'' - 18.0'';
Width (inches): 7;
Offset (mm): 35.
Rogue One
2022 Honda Pilot SE
spearfishman wrote:Hi everybody, does anyone know if it's possible to use a 16" rim from an older Rogue on a new 2016 Rogue SL? Our car currently has the 225/60R18 tire on it. But we are looking for a set of rims for winter tires.
Wheel General Info
Width (inches): 7;
Offset (mm): 35.
Welcome to NICO!
The very first post in this thread has the wheel and tire fitment chart.
brickbox
Car: 2011 Nissan Pathfinder 4x4
Can you someone here confirm that I can use 16" steelies from a 2010 Altima on the 2012 Rogue to mount winter tires?
JRIZZO
Car: 2011 Nissan Rogue SV FWD
Will Nissan Altima 18" OEM Wheels fit my 2011 Nissan Rogue?
Return to “Rogue Forum”
