thanks guys for the responses... yeah, I know they are supposed to fire up, go dim and then fire up again.... even the factory HIDs do that... what I was saying is that if a kit is going to fail with the auto on headlight feature, then its at this point that the kit would fail to turn on...toxik wrote:i don't think it's a question of analog vs digital but rather of quality. DDM is garbage, pure s***. So many people have problems with DDM it's not even funny. I bought my HID kid from retrosolutions, they got amazing Digitial HID kits, and had them for a long time now. Auto feature always works, both lights always fire, never missfired, never had a problem. Buy a quality ballast, and you won't have any problems with auto features.
no problem dude, and please shoot me another email and let me know when you will be applying to med school and if you plan on applying to Hopkins... I know for sure I will be on the admissions committee this fall, but I'm not so sure about the year after. the committee takes up a lot of time, and I'll be applying for residency the following year so I may not decide to do it again.The_alchemist wrote:on a side note I got your email about the med school stuff and I just want to say thanks a ton and it means a lot to hear your advice on everything, thanks again
Why?DJBeasy wrote:Id like to go 55W if I can.
They are claiming additional output form 55W, I figure for an extra $10.00 I'll put them to the test. Heck I figure Im rolling the dice with this kit either way, might as well bet the house, ya know.AppleBonker wrote:
Why?
I've been using the DDM Raptor V2 kit for the past 1/2 year or so, and have yet to have any issues with it. Auto-feature works fine and I've never had a misfire. Not trying to discredit your post, but can you post a thread containing the issues that people are having with them? It'd be nice to know what could happen to my kit.toxik wrote:i don't think it's a question of analog vs digital but rather of quality. DDM is garbage, pure s***. So many people have problems with DDM it's not even funny. I bought my HID kid from retrosolutions, they got amazing Digitial HID kits, and had them for a long time now. Auto feature always works, both lights always fire, never missfired, never had a problem. Buy a quality ballast, and you won't have any problems with auto features.
I think doc was referring to the base model of the 2.5. I'm assuming you have at least the convenience package?KilaDragN wrote:actually i have a 2.5 doc, and i have the auto-on lights. But from what i understand, when u turn on the lights, you have the bright flash, then it dims and bit and gets brighter. its the gas in the bulbs being charged up, at least that's what i was told, it just seems normal to me because i see a lot of HIDs that power up like that. I have the apexcones and i don't have an issue with the lights not turning on
The coupe's H11 related wattage is 55 watts... but the 55Watt HID kit is like ridiculously bright... you will most likely have oncoming traffic flashing their high beams at you thinking that you have you high beams on....DJBeasy wrote:
I did try searching for the Coupe's H11 rated wattage but for some reason couldnt find it.
Exactly this. And, as Hussain pointed out, the heat could warp the headlight housing. The non-HID stock headlight housing does not have as safe a cutoff as the HID reflectors (I think Darryl mentioned this). If this is the case, you will almost certainly be blinding people on the road. This is not a good idea.rjdmmfl1 wrote:The coupe's H11 related wattage is 55 watts... but the 55Watt HID kit is like ridiculously bright... you will most likely have oncoming traffic flashing their high beams at you thinking that you have you high beams on....
I have the 6000K xentec set and you dont even notice the hint of blue at all, just cool white.Hussain wrote:I had 5000k xentec HIDs and they were 35 watt. I loved those lights! sucks they burnt out on me. they were super bright! they would light up the whole road and on top of that, with 5000k it was a pure white with only a tiny hint of blue. the 5000k was perfect so I'd assume the 6000k would be a little too blue. and 35 watt is plenty of light.... I dont recommend the slim ballast xentecs though.
as for why not 55 watts? I remember a thread the other day with applebonker saying something about 55 watt blinds on coming traffic more and also it gets much much hotter and could even mess up your headlights. (with applebonker or dangerous said that).
Yeah I guess I didnt even think of that, very valid points. Guess Ill go extra cheap and buy the analog 35W Raptor set. Just hope that 5K is super white!rjdmmfl1 wrote:
Kila you have the actual DDM or the Raptor?KilaDragN wrote:From what i understand, the 5K with DDM has a bit of a yellowish tint, to kinda match with the stock color, but out put more light. the 6K is a good clear white, which is what i have. no hint of blue at all. hope that helps
Thanks man, I think Im going that route.KilaDragN wrote:DJ,I got the DDM slim ballast 35w 6K, and 3K for my fogs.
i dont think DDM digital ballast is good and have good stablity..... i use VVME 5K Digital slim hid kit for almost one year and still work well now...DJBeasy wrote:For those of you with the DDM tuning kit in their HEADLIGHTS...which wattage did you choose? Id like to go 55W if I can.
And anyone go 5K or 6K? I want hyper white, no blue or yellow at all.
Who got what?!?!
A_Hole wrote:I need your help guys. This thread made me actually look into HID's, I didn't know they were so cheap. So anyway, I'm about to order a couple sets (headlights, fog lights) but I want to know what I should get. I'm looking into the DDM 6000k for the headlights, but for the fogs, I see people saying 3000k. Should I get both the headlight and fog lights at 6000k so they match? I don't care for the yellow look, but I don't want to blind people with my fogs either.
Well, being that this thread is 5 months old, I have had the 35W 6K DDM kits in both my heads and fogs since that post and I couldnt be happier with them. No problems at all, straight white color, and inexpensive. Win, win, win.victorking wrote:i dont think DDM digital ballast is good and have good stablity..... i use VVME 5K Digital slim hid kit for almost one year and still work well now...DJBeasy wrote:For those of you with the DDM tuning kit in their HEADLIGHTS...which wattage did you choose? Id like to go 55W if I can.
Who got what?!?!
if you want hyper white color , VVME 4300K or 5K is better....
VVME 55w HID kits are 40% brighter than the standard 35w kits, so i guss 55w, 5k is nice to your car.... what do you think......
