Lurchdubious wrote:i may be interested in this as well...
do all 3.5's come pre-wired for fogs, even w/o the actual lights? is it very hard to run the wiring for aftermarket ones?
Mount the rectangulars and use the cutouts for a ram-air set upssjones wrote:I could mount the Hella FF rectangular model I've used in the past in the lower grill opening, but I think that would look goofy with the plastic covers for the factory lamps.
Surely someone has mounted aftermarket lights in the factory spot?
sweet.i'm guessing it's not as cost effective to buy the factory fogs?generic808 wrote:
Yes, to my knowledge, all 3.5's come pre-wired. The harnesses are located on the inside bumper, near the wheel well cutouts. You can access them via the wheel well or by removing the bumper.
As far as installing them, it should be a plug and play as long as you get the right bulb and harness. The thing you would need is a factory stalk/light switch, or you could just use the relay switch most aftermarket fogs come with. You can run the wire through the firewall and mount the switch somwhere on the dash using an existing switch plate.
Lurchdubious wrote:crap, i guess the only way to get the sunroof is to get the sport package with fogs & spoiler? the sunroof is a must have for the wifeymaybe i won't need to go aftermarket afterall...
Here's some info regarding the factory fog cost:Lamp Assy-fog R, L $155.00 per sideComb. Switch Assy $147.48Lurchdubious wrote:
That's my problem - I don't have any on my Altima. I sure could have used them last night going thru WVA and Western MD in the mountains, the fog was thick enough to cut for about 60 miles. Here's what the Hellas looked like on my Accord. I'd mount the same set in the same spot on the Altima but with the plastic housings for the factory fogs, I think it would look stupid. On the Honda, you had to cut out a section on each side of the bumper cover to install the factory fogs.I'm going out this evening to change the oil and investigate the factory mounting spots while I'm in that location to see if any round aftermarket lamps will work. With my broken foot, that's sure to take three times longer than necessary.......!#@#!mikemart wrote:ssjones: snap some shots of your fog setup sometime. I'd like to know what you think.
Lurchdubious wrote:^^^got any pics?
those look pretty good. ...i'm trying to picture what they will look like on the car...ssjones wrote:Please some pix. Did you use something like this?
http://cgi.ebay.com/ebaymotors...wItem
Idok wrote:I bought some Hella yellow projector foglights hoping to use the blank trim pieces that were in place of the fog lights but that wouldn't work. I ended up getting a sheet of plexiglass at home depot and fabricating a mounting platform that attaches from the back of the grill in place of the factory blanks. I used a sabre saw to cut some plexiglass to mouont the lights on then a hole saw to carefully cut a hole to push the fog light through. I bought some brackets at the hardware store to attach the lamps to the plexiglass. I had to use my dremel tool a lot to get everything ti fit right but the lights have been in place for about 3 months and haven't fallen off.Before I mounted things for the final time I tinted the whole plexiglass contraption dark ( not quite black) so most of the hardware is not very visible. I may try to reddo them in the spring but for now they work and don't look too bad.
Modified by Idok at 6:32 AM 12/16/2007
Modified by Idok at 6:33 AM 12/16/2007
Idok wrote:I thought these were glass, I guess I'll have to check. Thanks for the heads up. I sure wouldn't want to screw em up.
Idok wrote:I emailed hella to find out what type of lenses they are. I found a pair in JC Whitney and it says they are glass. I also loooked real close at mine and I am pretty sure they are glass. I tried to scratch them and couldn't.
k9eaglesnut05 wrote:I was just wondering if you ever tried to locate factoty plugs for your fog lights. My sister has the same car with no fog lights and I have the factory lights and stock but I see no wires or plugs?
