After I turn my car off.
Ilvemynissan
Car: 240sx s13
After I get done with a long drive or some hard driving I hear this sound coming from my motor at first I thoght it was some lightning in the distance but then realized it was actually coming from my motor. The closest thing I can describe the sound was a cofee maker sound just like it made that little deep bubbling noise.(deep as in the tone) and everything. My friend said that it could of been that the motor got too hot and some of the coolant is overflowing somewhere, I forgot what exactly he said. So I was seeing if anyone knows what that noise is and if it is bad or not.
Thank you!
Hijacker
Car: '92 240sx Convertible
'94 F-150
Sounds like air pockets in the cooling system. Rebleed it and make sure your HVAC is set to full hot (doesn't actually have to have the fan on, just the slider moved to hot)
Ilvemynissan
Car: 240sx s13
Ok....well this weekend probably I was going to do an engine flush with the BG. So if I do the coolant system too it should be fine then right??
zerothread?id=220948
^and do you know what you would have to do different with the SR than the KA?
