I'm not sure that having laminar flow in the middle with turbulent flow is possible. The velocity profile of laminar flow between two parallel surfaces is parabolic. In a pipe it would be a paraboloid. The velocity profile of turbulent flow tends to look flatter as the mixing effect that occurs perpendicular to the primary flow direction slow flow in the middle while speeding it up at the walls. This said, for a given fluid and pipe (or any flow surface) the difference between laminar and turbulent flow is the value of the Reynolds number. Which in the case of a given fluid and pipe will only vary with velocity. Turbulent flow occurs at higher velocities. Since the velocity profile of a laminar fluid is a paraboloid, the peak velocity occurs in the center of the pipe. I would think the turbulence propagates from the fastest moving part of the fluid. Regardless, the mixing effect is going to be quite strong and would be impossible to control in such a manner.Marenta wrote:I'm trying to find an aeronautical engineer because I want the fluid flow equations for turbulant, laminar, and turbulant/laminar flow for oil, water, steam, and air.
The purpose for this being in a turbo application. The most efficient flow is the turbulant flow with laminar in the middle. This flow will cause a cushion around the piping wall allowing the laminar flow to move quicker through the bends in the piping. However, I have a suspicion that it's based upon density, and really only applicable for higher density fluids like water and oil. If that's the case, then, in a turbo application the dual flow wouldn't be as efficient as completely laminar flow. The lower pressure (30 psi highest) for the air for the turbo isn't enough to see the effects of having a dual flow, vice the 1000s of psi that it'd have to be at.
I'm just trying to mathematically prove this, so, if anybody knows the equations for this, I'd appreciate it.
Also at least one potato.alms24sebring wrote:lots of physics and math...
This post is 100% true, at least when compared to what I've learned. I couldn't have said it any better.C-Kwik wrote:I'm not sure that having laminar flow in the middle with turbulent flow is possible. The velocity profile of laminar flow between two parallel surfaces is parabolic. In a pipe it would be a paraboloid. The velocity profile of turbulent flow tends to look flatter as the mixing effect that occurs perpendicular to the primary flow direction slow flow in the middle while speeding it up at the walls. This said, for a given fluid and pipe (or any flow surface) the difference between laminar and turbulent flow is the value of the Reynolds number. Which in the case of a given fluid and pipe will only vary with velocity. Turbulent flow occurs at higher velocities. Since the velocity profile of a laminar fluid is a paraboloid, the peak velocity occurs in the center of the pipe. I would think the turbulence propagates from the fastest moving part of the fluid. Regardless, the mixing effect is going to be quite strong and would be impossible to control in such a manner.Marenta wrote:I'm trying to find an aeronautical engineer because I want the fluid flow equations for turbulant, laminar, and turbulant/laminar flow for oil, water, steam, and air.
Given this, the effect you think may be occurring would not. Turbulent flow reduces or removes the boundary layer (the cushion you are describing). So even if such a circumstance of turbulence at the wall with laminar flow in the center could exist, your hypothesis would not hold. Its likely all moot anyways. You're likely dealing with turbulent flow in most if not all engine intake systems.
As for the math, there are analytical solutions for laminar flow. You can probably google laminar pipe flow for those. Turbulent flows have no analytical solutions. The math requires experimental data. Its been a couple of quarters since I took fluids, but you might look up head loss and Moody Diagrams as keywords to help you going in the right direction. I'm not sure what you might calculate as a qualitative analysis negates what you're seeking. Regardless, the fact that we do not have any analytical method for turbulent flows means there are many equations that may need to be considered depending on the specific scenario. A big part of that being the value of the Reynolds number. If you are really interested in quantitatively analyzing the turbulent flows, you might need something as comprehensive as a textbook.
That makes me feel better. But frankly, just don't ask me to do the math. It would take me days to figure it out and I have some idea of what to look for. Turbulent flow is intensely complicated.PapaSmurf2k3 wrote:I'm really not kidding, I read the entire thing and every bit of it covers what I was going to say. He's absolutely right.
I've actually been calculating crap all weekend, so this was actually a break for me. I don't know what possessed me to tackle 2 internships this summer.FlatBlackIan wrote:You deserve a ticket for exceeding the physichs limit on a Monday.
Because you are crazy smart. After reading your answer, I KNOW I need to get my a** back in school because you lost me after the first three sentences.C-Kwik wrote:I've actually been calculating crap all weekend, so this was actually a break for me. I don't know what possessed me to tackle 2 internships this summer.
We didn't study transitional flows too much in fluids, but from what I've seen in studying videos of flow is that transitional flows tend to shift back and forth between laminar and turbulent. It seemed like it oscillated in fact. I don't know if that is actually the case, but I don't recall seeing any kind of dual flow characteristics other than in non-fully developed flow. So such a dual flow could only exist in a very small section, likely after some disturbance.Marenta wrote:Any viscous fluid would have to have such a large pressure and precisely measured piping diameter in order to achieve the "transitional flow" required to provide that fluid wall at the edge of the piping. I just needed the equations so that I could prove the feasibility of the application in a turbo setup.
