SideWays=smiles wrote:A lack of back pressure in a NA motor will decrease torque output without greatly improving horsepower.
Exhaust scavenging =/= back pressure.
Quote »"Often confused is the concept of exhaust velocity and its correlation to back pressure. The conjecture is that back pressure creates performance, which is completely backwards. The idea with exhaust velocity in regard to exhaust pipe size and design is that if the pipe is too small or too restrictive the exhaust gases will not move through efficiently enough, only adding pumping losses through back pressure and cutting into combustion pressure and temperature by forcing some spent exhaust gases to stay in the chamber, basically just the opposite of scavenging. On the other hand, a pipe that is too large will not work correctly either, due to the laws of physics and cooling gases: if the pipe is too large the hot gas will cool, causing it to become denser (heavier) and slow down, the system not working efficiently because moving a heavier gas is more difficult than a lighter one."[/quote]Quoted from another forum
