Add LED headlights to 2011 m37x
WZRD927
Car: 2011 Infiniti M37 AWD
I have an 2011 m37x.
Can anyone suggest compatible LED lighting for the front headlights?
I feel like the front headlights aren't bright enough. I need something much stronger.
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Try this before you go nuts looking for brighter bulbs:
It's not a dim bulb causing your night-blindness!
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
VLED makes great LED lighting and I discovered them on this forum. I've bought about 20 different bulbs from them since 2009 and always been really satisfied with their products.
They show this as a direct replacement for your car: https://www.vleds.com/shop-application/ ... e-d2s.html
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Bulbs (especially the incandescent type) do get dimmer as they age. If you're simply trying to increase the brightness because the old bulbs have aged, I'd look into replacing those before shelling out a couple hundred bucks just to keep up with the Jones's.
The Key Differences Between LED and HID:
HID headlights are the brightest on the market, and the light they emit covers a larger area than halogen and LED bulbs. In fact, the area covered by HID headlights is nearly an entire third larger than the area covered by LED headlights. HIDs are also more effective at lighting up the sides of the road.
