jrc90240sx »
https://forums.nicoclub.com/jrc90240sx-u355.html
Thu Dec 26, 2002 12:26 pm
6K into a mustang would be running mid to low 10s, if not lower. (that is if there smart and go forced)
6k into a 240, and your running anywere from 14s to high 11s.
there is more you have to upgrade on a 240. like LSD, biger breaks, biger wheels and tires. a mustang owner would have have to add TC or SC, and dot legal slicks.
take the new cobra, all you have to do to get it into the 10s is change the pully, intake, exhaust, and some DOT legal sticky tires. and the cobra can pull over .95 g's so it would beat us (stock vs stock) in an auto X event.
My friend is building his mustang (99 v6). he is going to be building a block on the side to swap in later. for 6 forged pistons and rods cost less, then 4 of the same for my 240. he can build a builtproph block with good heads and cam, for about 3k. putting 260 rwhp and 340 lbs to the ground, and very boost happy.
I personly would never own a mustang on the dated setup it rides on (manily because i dont fit). I for one personly like my 240 more then his mustang (even a 03 cobra), the build quailty is much better, and have a much more advanced suspention/chase setup. we just lack power and displacment.
the new 05 mustang is going to be a power to be reconded with thats for sure. I just wish there was still a compact rwd import (other then the miata and s2000, witch i dont fit)
