SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Fri Jul 17, 2009 4:55 pm
If the car is in gear the right will move. The left motor requires a speed signal. If there is a problem with a speed signal you would know about it (ABS,Brake,Slip light illumination would be the primary concern) and the system would go into failsafe (off).
The AFS system is one of those often overlooked and misunderstood systems on these cars. Since ICC has been around many people know how that works but the M actually has a lot of small systems that do interesting jobs. Personally I find the AFS to be the most interesting system on the car.
