I've let the car get to as close as a half car length before hitting the brakes. The distance setting is set to 3 bars (furthest) which tells me something isn't working the way it should be. I've set it on clear days, both in highway traffic and in street traffic.mazz wrote:if you have adaptive cruise control it will activate when you set the cruise speed . you have another little button that control the spacing to another car in front of you. I assume you have gotten close enough to another car for the adaptive cruse to see the guy in front of you and slow your speed to match the guy in front of you. yes it is suppose to slow down and the car indicator should show a vehicle in front of you. When adaptive cruse is not working snow in front of sensor or heavy rain etc you get a warning flash and then you can go to regular cruise control without the adaptive feature
Mazz
That's what I'm saying. It's not working like this. I will set the cruise at 3 bars at 60 mph and it will get as close as a half car length before I have to hit the brakes to stop from rear ending the car in front of me.dmclone wrote:Tap the cruise control button(on/off) on the steering wheel once. You should then see an icon come up with 3 bars. 3 bars means that it will keep the longest distance. Then when you're ready, hit the rocker switch on the steering wheel. At this point you should see the speed display. This means your cruise control is working, As you get close to a car a car will appear in the display.
I couldn't watch this particular video (won't load at my work pc) but I did youtube ICC and the two that I watched were very similar from Infiniti. The longest distance the car senses is about 390 feet both videos said. That's definitely not happening.Debonair wrote:Not sure if you have seen this already but HERE is Infiniti's video about these features.
DCA works intermittently at best. I can't trust it to do what it is supposed to do. I did do a visual check on the sensor and it has normal dust and dirt buildup on there but nothing that is caked on it. I'll clean it off and see if that helps.SmoovC wrote:Does the DCA work, Swiss?
That's my next step. The car's warranty just expired on the 31st but maybe they will fix it since it's so close. How do you know about Zimbrick? Did you get your car there?mazz wrote:your unit must not be working .I clean mine when I wash the car but not before every drive. occasional in our area snow cakes up or heavy rain or even a low sun interferes with the sensors ability to "see" . DCA should work as well all the time and when it doesn't we get a warning signal call your boys up in Madison Zimbricks they can help they know their stuff
I see. I can't remember what I say sometimesmazz wrote:I noticed you mentioned getting service their recently and they did a good job. I am on my 9 th Infiniti I bought my 2006M there . I am just south of the border in lake summerset closer to Madison than Chicago for service. did this just start acting up ? or did you just try the feature for the first time .
This is why I want to get it fixed. If I have to pay out of pocket for it, it's gonna have to wait, if I ever do it. But being a week out of warranty when I discovered it (who knows how long it has stopped working), I would still expect all the functions of the car to work.SmoovC wrote:Regardless of whether is gets used or not, I would expect that it would work.
lol.mazz wrote:did you get a response on streeeeecccchhing the warranty?
