It looks like you and Dustkicker are having the same problem:
"At idle, and up to about 35 mph, I can rev up to 4500 rpm or more. But once I reach 40 mph, it won't exceed 3400 rpm! If I am going, say 60 mph, and punch the gas, it just sputters and creeps along. Same if I am going 70...takes forever to reach 80 mph. I can't risk trying to pass at any speed unless there is lots of time/room."
zerothread/177983
There's no good way to test the MAF, other than a Consult reading. And bad MAFs usually cause severe bucking and missing, rather than simply killing acceleration. If you could borrow a known good one, you could swap it. Anyone else here from Houston?
Check your CAS connector?
You can also bypass the FPCU to give the pump full power, with a jumper.
"Dennis' suggestion to ALWAYS keep an aligator-clip wire in your trunk comes into play while your're stuck on the roadside shoulder.
From the Q45 trunk compartment, simply:a) Remove the forward-facing bulkhead, AND ...b) disconnect the fuel pump control unit connector ... ANDc) Jump the ground wire (see photo).
This totally bypasses the fuel pump control unit, which will handily get you home (albeit with a fuel pump whirring away at top speed)."
zerothread?id=73822
Modified by 96Qowner at 2:58 PM 6/1/2006
