SrS13 wrote:That is very interesting I'd like to know how you did this if that is ok with you
Im not sure if its for all SR's or just mine so play at your own risk.I have ECU 63 because my SR came as an auto initially.Inbetween the third and fourth cylinders on the engine there is a plug with four wires going into it. The plug had always been disconnected because it caused my idle to be at about 1600 when I was driving. One day I thought "its stupid to leave four wires unplugged when only one was probably causing the problem." So I looked up the wires and found that the light blue wire was causing the issue. It was the Auxiliary Air Control Valve wire and I have no idea why it sent the signal to my Idle Air Control Valve to bump up the idle but it did. So I cut it, the only detrimental effects were that it was harder to coast in gear because that wire fed extra air into the engine whenever I would partially close the throttle plate, and that with an atmospheric BOV, the car would try to stall and die, thus leaving me to play the tap the gas game. So I got smart a couple weeks ago, soldered up the wire I clipped and hooked up a switch to it. Now I leave the valve open nearly all the time except when I am idling, or coasting and trying to get the idle down. The switch keeps my car from completely stalling out because it recovers way before 500 RPM's. Another job that the switch does is help my car from trying to stall during a warm startup. So before my car would try to die again if I didnt give it a little gas at warm startup, now it just drops RPM's a little and bounces back up.
Bottom line: Pull the plug while the engine is running and see if the idle goes down. If it does then plug it back in and set the idle to about 1600, then pull it again and see where the idle goes. If the idle goes to about 800ish then cut the light blue wire #113 off the ECU and simply add some wire and a switch to the AAC Valve. Mount switch wherever you want. ***Perform at your own risk***
Cyberkreig wrote:I happen to agree with you that is a turbo manifold or exhaust manifold; header makes me think NA. BUT it seems to be somewhat common.
I will acknowledge that the turbo manifold can be referred to as a header, however no company calls it a header, therefore it is not the most common usage. Header can mean turbo manifold but if you use it in this forum I can only assume (as I rightly have with other people in the past) that you do not know what you are talking about and are only defending the term "header" to cover your a$$.
