I agree with you completely. A coworker of mine was looking at a Subaru Legacy with the CVT, and my advice to him was that without some sort of manual override, I think the average person would go crazy. Granted, I don't use my paddle shifters much at all, but sometimes I don't feel like waiting for the CVT to realize, "Oh, you want to take off a bit faster than normal." or, "Oh, the selected ratio does not apply because you're actually trying to go up a hill."Rogue2008 wrote:I think they should provide the paddle shifters with all CVT cars.
Nissan released a tech bulletin regarding valve body issues awhile back. Supposedly it only affected the '08 models.buffalorogue wrote:The word from the dealer was ...of course they could not reproduce the problem because they didn't drive it very far, but there were error codes on the computer. So, they contacted Nissan and was told that it was the valve body and so, I'm getting a new transmission. Will be curious to hear how your long drive went, PA2.
NTB09148 - SB Altima/Rogue/Sentra; MIL "ON" w/DTC P0840/P0845/P0744/P1777
* IF YOU CONFIRM Any of the following DTCs are stored in the TCM: - P0840 - P0845 - P0744 - P1777 ACTIONS Replace the Control Valve Assembly with the part listed in the Parts Information section of this bulletin. Reference SECTION TM, CONTROL VALVE Removal and Inspection in the appropriate ESM for directions. Erase the EEP ROM calibration data in the TCM and allow it to recalibrate. Reference NTB08-064; CVT AND 5 SPEED A/T INITIALIZATION INFORMATION for directions.
Well, if they give you a new transmission then you are lucky, they only replaced the valve body on my car. So far my long drive is going good i'm in frederick, MD and everything so far is good stopping and going up the long hills here in Harpers Ferry, W. VA, everything as it should be. Now when you press on the gas after a long run the car goes, so guess that was the problem.buffalorogue wrote:The word from the dealer was ...of course they could not reproduce the problem because they didn't drive it very far, but there were error codes on the computer. So, they contacted Nissan and was told that it was the valve body and so, I'm getting a new transmission. Will be curious to hear how your long drive went, PA2.
Weberrider is referring to Nissan's CVT warranty extension. The warranty period is 10 years/120,000 miles and applies to all Nissan vehicles equipped with the CVT... he did not purchase it. Read more here:Rogue2008 wrote:What? Extended warranty does not cover electricals?
Hmmm, I've had something similar happen when driving on a loose surface (sand, gravel, snow). If you spin the tires too much, the system seems to go into this 'limp mode' and acceleration/power is reduced. It's only momentary and goes away within a few seconds. There could well be a protection mode built into the CVT that prevents damage under certain conditions. Perhaps this could explain what we are seeing? Unfortunately only the engineers at Nissan would know for sure....Nick 568 wrote:This usually happens after a somewhat large "jolt" to the vehicle. I've had this happen to me twice that I can recall. Drove down an incline on a driveway too fast, hit the even roadway fairly hard, and then I had no acceleration at all. Another time was last week when I was driving down a muddy off-road trail and hit a bump fairly hard. 'Tripped' the system, and had to just coast for a few feet before anything would happen.
Shutting off the vehicle and restarting it also solves the issue.
I can tell you one thing and that is the guy who told you that does not know what he is talking about.Leslie45 wrote: After reading these posts I decided to call a dealer to see if they have had similar problems with people bringing in their rogues. The guy there said no he never heard of it. He asked me if I had premium gas in it. I told him I didnt even fill up yet. Still has the gas the dealer put in it. He said to try putting premium in it. That the car requires high octain premium.
Hi Sheena,Weberrider wrote:The problem was a stop switch that tells the transmission that the car has stopped and must resume movement in a lower range in the transmission. The switch was failing and the trans did not get the signal that I had stopped. Basically like starting in 4th gear from a dead stop. Cost of repair was $158.00 and they did it in about 2 hours (they also did the steering recal)l.
