maxima278 »
https://forums.nicoclub.com/maxima278-u20438.html
Sat Jun 11, 2005 6:44 pm
I have a 96 240SX SE originally automatic car that because of electrical fire, I put an entire engine, manual transmission, and wiring harness (from ECU all the way around the headlights and into the steering column). Most wires and connectors matched up, a few did not, and I really do not know the relevency behind the ones that didn't. I've been driving the car with very little problems and most everything seems to be in good working order. But, I did not attempt to use the AC until today when I had my father in law vaccuum it and charge it for me. Afterwards, when we mashed the AC button on the dash, the engine would go into fast idle, but the compressor would not turn on. After jumping the relay in the box under the hood, we were able to get it to come on, and I drove it home with the ac on, blowing good cold air, better than my maxima even. Just can't turn it on and off like that, and leaving it jumpered would surely drain the battery. I know there is a safety switch that will not allow it to come on if it is low on freon, but we did put 3 twelve oz cans in it and jumpering the connector that goes into the receiver dryer cannister did not seem to help either. Is there anything I can do to fix this problem without compromising the safety device? If I run out of freon I don't want to be able to kill the compressor. Is 3 cans not enough freon? Am I screwed? Should I just add a toggle switch and risk it? (would rather not) thanks
