maxima278 wrote:It's funny I've been doing residential electrical work for four years and some of this stuff about the meter has never come up. How do I check for ground? Is this device the one that controlls the cycling on and off?
Thats because AC and DC are 2 different types of electricity. AC is alternating and doesnt have ground persay it has a hot and neutral [both lines are power at 60Hz. DC has a hot and ground and never changes its polarity. To check for ground you do it the same way as you did when you were looking for AC switching. you will see a voltage if its not grounded. We use a power probe to test live electrical circuits, it has a led on it when we hit ground the led lights up green, when we hit power over 6 volts it lights up red.
This device tells the ECM what the evap temp is and prevents the A/C from freezing up. If bad it will not allow the compressor to come on. This is a pretty common problem on newer nissans.
