austins240 »
https://forums.nicoclub.com/austins240-u9789.html
Sun May 27, 2007 1:43 pm
follow the reccomendations of your engine builder. Depending on the final hone, you will have to break in the engine in different ways. Also, depending on how the motor will be used and how long you want it to last will change break in procedures.
I reccomend changing the oil after bleeding the coolant the first time and then every 200-500 miles after that. cheap oil, no need to spend $40+ per oil change. use stock (or better but no FRAM) filters and magnetic oil plug.
my friend just had his built. according to the builder, he had to do 1000 miles under NO boost. Keep it under 4k rpm etc. we wired his waste gate open to help from building boost. so far so good. he just passed 1k, changed oil at 200-300 miles and is now boosting.
