You are way behind the curve here. Substantial damage has already occurred.Alcyone wrote:I have a 93 Q45 with 206k on it and the transmission fluid has started to look a little brown.
Sounds like a plan since every service shop and all mechanics are a bunch of rip off lying scumbags. I usually do my own maintenance. This was a good reminder of why.qship96 wrote:Go gradually on the old girl with 1 drain/fill a week in your driveway for 6 weeks in a row.
In this guy's situation, this is the best route for to go. Do NOT perform a BG flush on your transmission with no prior history. The crud that is in there now is actually "helping" your transmission to perform. If you flush it away, you WILL do more harm than good.qship96 wrote:Go gradually on the old girl with 1 drain/fill a week in your driveway for 6 weeks in a row.
This is true! I can't believe people were actually telling this guy to perform a flush when it's evident proper transmission service has not been performed. In your case OP, just do drain and refill because damage is already there. The idea is to change fluids BEFORE it visually looks/smells bad. I perform my next exchange at 205k.Victor wrote:Two transmission mechanics told me that power flushing an old transmission that hasn't had regular maintenance will often do more harm than good. One shop showed me some discs (I don't remember the proper name) that had been ruined by power flushing. Also old seals can be damaged.
I wouldn't ask for oil fluid lol, but as far as the BG flush machine, I stand there and watch them. As far as parts, I actually do this with spark plugs. I tell them to make sure they put the used spark plugs in the box the new plugs came out of. I usually tell them that I have a warranty on the plugs from a local parts store lol.unknown007 wrote:Just make sure you always ask for you old fluid (dunno if it's possible) and replaced parts (has to be) because some shops don't do nothing and just clean the think up and make it look like new.
Please define the "power flushing" procedure!Victor wrote:Two transmission mechanics told me that power flushing an old transmission that hasn't had regular maintenance will often do more harm than good. One shop showed me some discs (I don't remember the proper name) that had been ruined by power flushing.
It's draining as I type this. The fluid looks exceptionally bad. Very black and mucky. I very rarely drive the car so I'm not sure a drain a week is the best way to go. Do you have a recommended mileage before I should do the next drain? And just to confirm, 6 drains correct?NightRiderQ45 wrote:This is true! I can't believe people were actually telling this guy to perform a flush when it's evident proper transmission service has not been performed. In your case OP, just do drain and refill because damage is already there. The idea is to change fluids BEFORE it visually looks/smells bad. I perform my next exchange at 205k.
Thanks, will doqship96 wrote:Be sure to measure amount drained and refill exact same amount with new atf. Drive it for 50 miles or so then repeat process.6 times should get you very very close to 100% new fluid- may need a few more,check fluid color on dipstick after 6 drain/fills compare to fluid color of new atf in bottle-that is your goal to have them look the same.
That's why all new ones come with 10% used fluid for starters!qship96 wrote:I would agree with you that 80-90% new fluid is good enough......
So Brian, if you change your motor oil at 3,750 mile intervals, you are saying that at 375 miles {10% use} that the fluid is "bad" and "full" of fecal matter......sounds kinda retarded, doesnt it?maxnix wrote:That's why all new ones come with 10% used fluid for starters!
What you are basically debating is how much fecal matter is tolerable. It's truly absurd.
I'll second that. Roughly 5 quarts came out of the pan. After putting 5 quarts back in the fluid on the dipstick looks a lot better. Plus, ATF isn't cheap.Victor wrote:I think six fluid changes in a row is overkill, and bad for the environment. Look how much ATF you will be wasting and that will have to be disposed of (Please don't dump it down the sewer). Two changes seems like it would get 80 to 90% of the fluid changed, so who cares if 10 or 20% is still dirty. Before you started 100% was dirty. And changing your ATF every time you do an oil change is an unneeded ridiculous waste of precious resources and money in my opinion
