A pre-searched vacuum routing concern...
leroiboy
Car: 1989 Nissan 240SX Coupe
ok, here's the deal: currently my vacuum routing is like this:
large nipple on top of intake goes directly to wastegate
small nipple on top of intake goes to fuel pressure regulator and blowoff valve
in my search/research, i have read to my understanding that the large nipple should be used for the bov only, the small nipple is to be run to the fpr, boost gauge and/or boost controller. also that the wastegate has its own dedicated source from a nipple on the intercooler piping.
so here are my questions:
1-is there anything wrong with my routing as listed above?2-i only have a nipple one ic pipe(the one going to the intake manifold)-can i use this nipple for the wastegate?3-if my routing is ok, can i tee off of the bov/fpr in order to hook up my boost gauge and manual boost controller?
thanks guys and gals
duffman1278
Car: 89 240sx Hatch, the wildcats!
Why don't you just run it the way it should be instead of doing it the way you want? Its set that way for a reason. Just do your vacuum lines like your search says. That's correct, yours is not. Save yourself the hassle.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
duffman1278 wrote:Why don't you just run it the way it should be instead of doing it the way you want? Its set that way for a reason. Just do your vacuum lines like your search says. That's correct, yours is not. Save yourself the hassle.
Do it the right way.
leroiboy
well i have absoulutely no problem running it how it is "supposed" to be. which is why i asked in the original post if the nipple on my cold pipe(intercooler pipe going to intake manifold) can be used for my wastegate signal- so can i use that?? thanks for the replies and help.
