I am very sorry it took so long to get back to you. Finally got everything running the way I wanted but had to leave for a friends wedding and had no internet access.
As far as clutch fork movement, I'm getting at least an inch of movement. I'm using a Maxima clutch master cylinder with a Z32 slave cylinder, but the piston size of the Max's master is the same as a Z32 so travel should be the same. I'm running a brake line from the master straight to a braided line connected to the slave, no damper stuff in there.
