mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Sat Jun 30, 2007 12:33 pm
Still not able to put it into gear either?
The only things really left would be the hose, the damper, the clutch fork or pivot, throw out bearing, or the pressure plate itself.
You could try putting a piece of metal between the transmission and clutch fork, then lightly press the clutch pedal to see if there's any more pressure (I wouldn't be too rough on it just in case there is good pressure, could mess something up putting too much pressure on it like that). If it has good pressure it'll be the fork, pivot, throw out bearing, or pressure plate and if its not good its still in the hydraulics.
I'm going to go out and mess with one of mine and see if I can figure out more.
