See my previous post.elwesso wrote:
DIFF modifications IMO do not do that much... A high stall converter is a much better bang for the buck (WHY DONT PEOPLE UNDERSTAND THIS?)....
Its a lot of wasted time and effort on something that doesnt really do much of anything... )
Haitian_King wrote:
Is a high-stall converter something that can be added on to a stock trans? Or does it require a whole new one?
Is that for IPT or Level 10?mtcookson wrote:The Q uses the RE4R03A so their listed price for a complete build is $2,975.
I was just hoping to get a little more 'grunt' at the lower rpms in daily driving. You just talked me out of it.............thanks.Q45tech wrote:What are you trying to accomplish with a 3.90 that a 3.538 cannot accomplish?............... besides increasing the engine rpm 10.2% vs old speed in each gear and decreasing your highway mpg by at least 1 mpg.
I actually have a NICO ecu that I haven't installed. When I ordered the ecu, I also installed a later tcu with the first gear start, and swapped out my original ecu to send in for the NICO mods. Interestingly, with the 93 ecu/tcu combination it revs to about 7,200 rpm, hesitates, then shifts up. Does this seem normal? I don't drive full throttle much in Seattle proper, so I just haven't updated to the NICO ecu which I plan to do over Christmas break.Q45tech wrote:A less expensive method is an NICO ecu reprogram which will do the same or better to 60 and improve quarter mile by 0.4 seconds to 14.8/96 by staying in 2nd until 7300 rpm................assuning the engine is good and has adequate compression.
OK, this seem like a better way to go than a diff swap to get the result I want.elwesso wrote:you cna add it to a stock trans.
3Q Jay redid his valve body, maybe he could shed some light on the situation.
IMO a hi-stall and shift kit changes how the car is... SO much more fun!
http://www.trademotion.com/par...gid=1maxnix wrote:OEM is $2,200 + frieght less $400 core refund + core freight.
So. The price shown on the website is what I'll be paying? How long will a rebuild take? Something that can be done in a day?elwesso wrote:Why would that matter? Theyre replacing everything if you have them rebuild it!
