JohnPa wrote:
However, I have the dreaded slow 2-3 upshift in cooler weather, so I just looked up the old posts in mid '05 by you and 3Q Jay (re4r03a vs. re4r01a valve body - thanks to 96Qowner for the reference ), but the thread quits before I could find out what either of you finally did to solve the problem.
Thanks
John, I bought a new separator plate from IoS, and drilled a couple of oversized holes to aid the 2-3 shift. one (biggest drill-out) was to increase the feed pressure to the high clutch pack. other was to relaese the band. (recall that the 2-3 shift is a combo of the high clutch engaging simultaneous with the band disengaging).
mixed results. it shifts absolutely crisp at mashed WOT 7000 2-3, but the 'around town' 2-3 is actually drawn out. not in the usual way with an overspeed, but actually an 'overbrake'. the high clutch now engages BEFORE the band releases (see vb mod info above). in a similar way, the 4-3 at 2/8-3/8 throttle downshift is delayed as well.
