damn, i tallied mine up the other week, and WITHOUT the cost of my SR, im over $23k.... granted i have a lot more suspension/driveline stuff than the average bear.OutToWinPAHC wrote:I dont wanna know, too damn much. Its not cheap, heads alone ran me 1300, trans and swap gears is a good 2400 plus freebies. I'm probably about 20,000+
Why is that an issue? An alignment takes all of 15 to 20 min if you know what you are doing. I think I aligned my S14 13 times last summer. Once my race car is finished I will likely have to align it before every event, plus often times you end up re aligning it between Friday stages and Saturday stages due to broken/bent parts.mrgreeneyes wrote:and you plan on aligning/realigning before and after EVERY time you wanna go to the strip?
nahhhh.... thats just asinine dude. NEVER gonna work out that smoothly.
just trying to shed some realism on this fantasy parade
Does 9 second 1/4 miles240lookis wrote:i am no help on this issue.
but that s14 is bad a**.
I was going to start a thread like this awhile ago.Was curious to see if my psms will put me in the nose bleed section.Don't think they will.The rear bottom brackets are kinda small.OutToWinPAHC wrote:how high do your coilovers go?
^ This.Bumnah wrote:Forget all that, get some flares!
Better yet, tub the rear, and put in a 9" ford rear end.
damn wtf are you guys using. i've counted mine and I am ~15k with rb25 and full suspension & brakes, silvia front, work wheels, etc...mrgreeneyes wrote:
id've thought youd be in the $25k plus area once you tallied up all your crazy coolers/heater cores/ random gadgets you added.
