FSUDrifter »
https://forums.nicoclub.com/fsudrifter-u36244.html
Thu May 31, 2007 8:11 pm
my car is kinda having the same problem so i'll just post here rather than start a new thread.
Was running fine, took motor/transmission out to change timing cover/oil pump, put everything back in the way it was, here is the problem:
My car feels good if I don't floor it. It will build lots of boost but the AFR drops to 10 and the car has absolutely no power. It seems to do it a little more when warm than cold, but I can't tell for sure because I never go above 3k until at NOT.
Could bad spark plugs cause this? I have some new iridiums but I'm scared to put them in and foul them up.
I was thinking that the clutch was slipping, but it's a new clutch and if I drop it it grabs hard.
Also thinking boost leak, but it builds boost, jsut the fuel is not getting burned.
Am I running hot and getting my timing retarded or something?
