Anyway so the transfer case linkage portion was easy to disconnect but the part of the same linkage that connects to the transmission is stumping me. So there is a little block that the linkage goes inside of with a rubber boot. I've tried removing the two 10mm bolts and prying a bit on the block to no avail. Is the linkage removed higher up somewhere closer to the knob inside the cabin? Please help
Also guys I don't see the housing at the rear of the transfer case clearing the exhaust. If I disconnect the bellows will the exhaust drop back/down far enough to get the transmission/transfer-case assembly out?
I really appreciate any help
Michael
