InsanityInc wrote:On the intake manifold, I don't think you actually have to use the OBD1 manifold.
I know the upper part of the OBD2 manifold is a direct bolt up to the lower part of the OBD1 manifold, as it's on my car right now. Also, my car is using all the idle valves from the OBD2 lower manifold and they work fine. I wouldn't be at all surprised if the entire lower manifold worked completely fine with an OBD1 car, considering the only other thing on there is the EGR temp. sensor.
did you try changing the sensors themselves so you can use the 96-98 manifold with the 91-94 harness? im pulling my 93 motor out tommorow to swap in a 97 ka, so ill see whats up with that.InsanityInc wrote:You'll want to save your TPS (the sensor on the TB). I think that's different in the OBDII cars, and it's VERY important to the proper operation of your car.
My car still idles correctly on warm up, and bumps the idle appropiately (electrical load/AC on). But like I said you have to change the sub harness, because the connections on the backside of the IACV-AAC valve are different for OBDII. Also, the upper manifold on the OBDII KAs has no secondary butterfly valves (which is a good thing, really), so you'll need to cap off the vacuum line going to them.
no, they arent. you may as well have put a s13 motor in.tonynalli wrote:right but the basic principles are the same...
why do you say that? kind of a random statement....DjPantsSpecR wrote:assuming youre using the s13 harness. i can only assume you either missed a ground on the back, like the one that plugs onto the firewall.
that is correct sir.DjPantsSpecR wrote:if you didnt swap the s13 vacuum gallery onto the s14 head, those two plugs go to the PAIR and SCV solenoids.
You removed the SCV with the S14 upper manifold, and if you removed the large black box assembly from right next to the exhaust manifold, then you dont have a PAIR valve anymore either, so you dont need either of those two plugs, if they are black and brown.
why cant i use the s13 alternater? im still using the same electrical system...DjPantsSpecR wrote:the two power steering pumps are the same, and now its not possible to use and s13 alternator anymore, if you try you'll blow the fuse and possible the engine control fuse. but you can upgrade to a 90 amp from a foglighted s14 se for no additional cost from nissan (for the higher amp models).
