97y33 suspension order form is wrong??
NyRider
Car: 1997 Infiniti Q45
I've searched and begged (damn sucks) and Im still unclear as to what to order for my suspension upgrade. I am looking for comfort not ride handling or lowering. So my best bet is OEM correct?? well if so I know I have the choice of replacing the strut inserts and bushings. thats about all I get from my searches. so I am going to put this order form pic up and hope somebody can tell me what im missing and what i dont need again this is for back and front suspension.AnyHelp
It would be alot easier if the forums were broken down like the acurazine.com forums. something like infinit->q45->(97-01)anyhope of this ever happening. this way when I get a return of 1250 results on suspension upgrade I dont have to read 1249 on the 92-95q45 before I get to the FY33's
NyRider
well label them colums 1 - 10 for easy refrenceing
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Try using FY33 and the less correct Y33 and the more correct (for parts) FGY33 in your searches.
There are inserts for the front only, full replacement in back. Get the bearings and all rubber, spring mounts if you live in the salt belt, which you do. IoS will let you return unsued parts. They are the best way to search for parts.
I think you have the stiff rear sway bar, but there is a thread that will confirm that.
With Q45 becoming more rare with each succeeding model, I doubt the forums will ever be split. There is a thread on that also.
Modified by maxnix at 4:51 PM 2/11/2007
NyRider
Thanks man for clearing that up. I usually just search with q45 but will try fgy33. thanks for the help I really appreciate it
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I'd stick with Y33 as many more members use it and it might also pick up FY33 and FGY33.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
I've recently posted a thread that had all part #'s for rebuilding suspension. However, I have an Anniversary Edition so some of the parts may be different.
zerothread?id=223222
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
the shocks will be different as you have the adjustable ones. I think the rubber and bearings are different also.
IoS knows all.
Q_SHIP
Car: 1999 Q45T with a billion miles.
Inserts for the Non adjustable will go into the adjustable casings but you loose the function. It does keep things cheap though.
