Don't think we are questioning the results per se, just the methology. The repeatable accuracy of chassis dyno is less than stellar. Throwing out numbers without rigorous controls even publishing dyno charts is less than accurate as they are the easiest things in the world to jeep.
!!!The owner may not even be aware the numbers are tainted. Presenting them in perfectly good faith!!!!
Unfortunately a chassis dyno is usually all one has for inexpensive same car comparisons.
The primary unintentional errors come from not measuring and reporting temperature changes of the fluids, tires and dyno rollers.
Not returning the engine to baseline [back to stock] and doing another series of measurements is the typical fault......as the hotter the oil [rear diff especially] the lower the frictional losses will be.
http://www.depac.com/applications.htmht ... ts.htm#TOP
"Every dyno tuning shop we’ve spoken to claims to be honest, and yet we often get letters from readers who have been shown before-and-after graphs to prove that there has been a worthwhile increase in power, but they’ve noticed no difference on the road. It’s not always a question of dishonesty, it also comes about because the operator, or mechanic, is seldom sufficiently trained, and does not understand the effect of some of the errors he’s introducing into the measurement process. "
http://www.maha-usa.com/en/files/0523b03v.pdf"Chassis dynos are great tuning aids but they only give a approximation of power output as some of the important variables are not accurately controlled. Certain magazines seem to think that results obtained from chassis dynos are the gospel. They are not. In one recent independent test, hp figures varied by 11% simply by doing the runs in different gears and in another test, results varied by almost 4 % by doing the runs with a different wheel/tire combination. Tire alignment has been shown to affect results up to 3% as well. Note that Engine hp DID NOT change here yet the dyno recorded an increase in hp at the wheels. One can only conclude that inaccurate moments of inertia and correction factors are being used."
http://toyotaperformance.com/dyno.htm
http://www.pumaracing.co.uk/power3.htm
