Terry,Tgvince wrote:Heres the full chart. - Terry
Could you rescan eliminating the header? Perhaps I could read it then.
Thanks.
Q45tech wrote:Try 3-4-5-6-10 stock dyno runs change nothing [touch nothing under the hood]! If you do them within 5-10-15 minutes of each other you will see the torque and HP increase [by magic] as the oil ATF, diff and tires increase in temperature.......asuming that the hood is open and cooling air blowing on the engine."
Have you ever done this personally? Id be glad to do this to your car:). I can assure you when its 105 degrees outside and 95 in the shop with 150 mile trip to the dyno at 85+ miles per hour the car was up to the max temp after the first dyno pull. The temp on the consult after the first run was 201 degrees. In my experience with Nissans on the dyno with the first three runs you get more HP after the 3rd your heat soaked hood open or closed external fan blowing or not.
One always reverts to unmodified after each modification as a scientific check........that friction changes are not squewing the results.
OK ill add that to my dyno testing procedure.
"Dyno are great marketing tools to sell products unfortunately more than 50% of the published ones are not accurate [in my opinion] since the producer pays for the dyno time."
So this does come down to me trying to pull a fast one to make a couple of bucks. Dont lump me into a catagoy reserved for companies like Stillen. 5%hp is the minimum this setup made, if you look closely at the dyno graph...But i didnt grab that larger number To "market my product". The methods you describe above are not far from "test to distruction". I have minimal dyno time as we speak with the Q, however ive dynoed my Turbo sentra in all differnt times of the year on at no less than 4 different dynos, is it plain coincidence that they were all with in 2-3WHP?
"Many people think published engine HP is accurate, maybe within 10% it is........They take 5 engines and dyno them, some companies use the highest, some the lowest, and some average........lots of pressure to shave decimal points here and there."
But this is why we established a baseline, right?
"Chassis dyno are all we have to measure improvements, other than accurately timed quarter mile runs."
My driving sucks so ill get a Gtech PRO and see what that says.I may attempt to run the 1/4 at the next "run whatcha brung" event...But i am afraid you will find flaw there as well.
"Mathematics and computer simulation is used for all engine design.............everything usually works out within 3% of projections."
Thats awesome, Im not trying to make a bunch of old men happy about there quiet luxury car...Im trying to find a couple % HP.
"The MAF [on Q] is extremely accurate at high flow rates and the translation from grams per second to horsepower has been proven time and time again the only unknown is the FMEP [frictional mean effective pressure] ....how much negative HP is consummed in setting the next cylinder up and ready to fire."
"The main problem with chassis dynos is they don't consider the EXTRA load of air induced friction and how the engine behaves with this 10- 90 -130 HP load...............how can one size drum with varying tires and vehicle weigh simulate a real world acceleration on a road.
Im not really sure how that coralates here? HP is HP. What your talking about is power to wieght ratio. So if i get a bone stock Q to race me in the 1/4 and i have the CAI installed if i beat him by a 1/10 or 2 then you could simply say its that 10% margin and i have a stronger engine or my fluids were hotter or i ran more tire pressure or or or....
This is where the DYNO comes in....Establish a baseline and then test the parts. Were talking about a very state of the art 238C chassis dyno not some hydro braked 1970 dyno.
Q45Tech...Where do you live? Willing to come to Phx to "supervise" my dyno tuning? Seriously. Or perhaps someone near the area that you would trust?
I am done with this discussion....Ill open a poll if i get enough guys interested ill continue plugging away... if not...the Q will continue having ZERO aftermarket support.And ill have one quick Q...
TerryWondering if this is all worth my time....
