Thank You... does the MAF cause the car to stall or buck when warm?..The car also has an issue with a oil leak?? First they told me it was from the oil pan...Found later to be not true because car was still smoking but no overheat.....?....Then It seemed to stop and now all of a sudden when I started getting all these repairs the problem is back?? I was told it was a valve leak and told it was sealed and fixed but still a little nervous all around to drive the car:( Beautiful car and paid for so dont want to give it up...not w/o a fight! Don't want to pay someone to drive a car....right now:)goody94q45 wrote:Oh, and since Brian hasn't shown up, Welcome To NICO.
I would love to take to dealer but the closest one is more than 65 miles away and with all the bucking and stalling leads me to believe driving long distance right now isnt smart...I think I will take it to someone else and try to get another opinion.... Like I said the car has Been good since the weather has been cold and gives me no prob's but when it gets warm I know at any minute it will act up!?qship96 wrote:I do not believe the oil leak destroyed ANY sensor on,or near the engine! Take the car to the Infiniti dealer,pay for a complete diagnostic of problem,then decide to fix there or elsewhere with a exact list of what needs done-these cars really should never be trouble-shooted by someone who is not trained on this specific model-dealer prices may seem high,but in the long run,may be cheaper due to no guessing and just throwing parts at a problem in hopes of finding a cure.
I think recently that too much emphasis is placed on cleaning MAF sensor wires that don't require it unless air filter change intervals have been abused. I would focus on the connectors themselves. Then have the fuel pressure measured. No mention if fuel pump that was used to replaced the malfunctioning one was OEM, nor if a new gasket was used, nor if the FPCU was inspected.96Qowner wrote:It's a bad MAF. Do what goody said - work on the MAF connector and clean the MAF according to the instructions on Q45.org. It will at least improve, and give you time to find a used MAF if it doesn't fix things entirely.
The classic symptoms of a bad MAF are bucking/jerking and suddenly dying, particularly when coming to a stop.
