96 maxima....bose/poineer deck question
9maxi6
Car: 1996 Nissan Maxima
whats up...this is my first post on here...i have a 96 maxima and i am trying to install a pioneer head unit in it....i have installed tons of these before and i know what im doing but this seems to be alot har der than most...first of all im sure this is a common topic on this forum so id appriciate any help i can get
first off, how the hell do you get the stock radio out?
next, best buy and everywhere else is trying to sell me hundreds of dollars worth of stuff just to make my new deck "compatible with the bose system"....is there any way around this or can someone help me and let me know EXACTLY what i need? cause even when i ask them its wayyy too confusing...thanks guys
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO.
zerothread?id=138399
This should help you on removal.
9maxi6
thanks alot bro
dumpstafresh
Car: 98 infinity i30
i just installed an aftermarket deck, keeping the bose amps and speakers with success.
the bose head unit doesnt have the regular (40 watts x 4) speaker output that most hu have. instead it just has pre amp outputs (like the red white rca plugs on the back of an aftermarket hu). each one runs to one stock a stock amplifier, then to the speaker.(on my 98 i30, each speaker has its own amp.)
if you have 3 pre amp outputs (front rear and sub) on the back of your deck you don't need any any special adaptors. you can just splice a couple rca cables and connect them to the speaker inputs.if not you can buy a hi level to low level adaptor at walmart for like 10 bucks.
i bought a regular adapter at best buy for $20 so i wouldnt have to cut any stock wires.
you have to connect the amp on/off wire to a switched power source. i just used the remote wire on my deck.
i know this info is allready out there, but i had a hard time finding it. so i thought id try and make it easy for future searchers.
