95 s14 offsets???
nismo_power
Car: 91 240sx fastback se
i have 16 by 8 rims with +28 and +38 offsets...i was thinking about getting bolt on spacers that were 15mm and 25mm because i remember reading somewhere that for every mm of spacer then the offset will go that much more negative... correct me if im wrong...so this way i will have all four tires sit at +13, so how will my car look with +13 offset???my wheel are super advans ver.2...will this be too much or will it sit flush???can i get some pics if u guys got any with this offset on a 95 s14...thanks
Slide_Society
If you have everything with you, I'd just bolt that **** up to see how it looks.
Bolt on the wheels since you don't have the spacers. Then take a tape measure and measure out however much spacer you intend to use and see where it lands.
nismo_power
yeah but was i right or wrong about the offset thing???
r3v_v3ng3
Car: 91 fastback ka-t
yes your right about the offset thing. it will stick out more. +13 offset is different look from different sizes. you can check for people having the rota grid i think its 16x8 with +10 offset and you will get an idea or just bolt it on
nismo_power
no pics anyone???
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Im running 16x8 +10, the fitment is great, yours will sit slightly more in with +13.
