"I did hold the gears out there so that I had only one shift. "
See I told you!
You can't trust the tach at 7,000 rpm [because of velocity of sweep] best to let the ecu do its thing. When you read with Consult you'll never see 7,300 rpms........7,250 maybe ocassiuonally real rpm.
Now that we have established that you are staying in second gear [like you should for quarter].........14.6/96 is crossing the timing light at 7100-7200 rpms.
Get a Consult and give me the 6,000-7,200 rpm: MAF voltage, ignition advance and fuel injector time in 50 rpm increments.
Gotta know how much air flow you have [4.30 volts peak or 4.4 ] .
Everything now will be extreme fine tuning as there really isn't much to play with from the plenum outward.........[only 17-19" WC restriction] would be 12 HP loss and only 5-6" is in front of MAF.
We must know if the mixture is still too rich even with JWT ecu [probably because they don't want to get sued].
You might try Redline High Temp Syn ATF it might get you 0.2 seconds [can't be used in cold weather]. I used it for 2 years in my Q transmission. At $8 x 11-14 quarts cheap if it gets you 0.1-0.2 secondshttp://
www.redlineoil.biz/redtech4a.htm
