just because someone makes it doesnt mean its a good idea.Metal4Life..95s14 wrote:why would brian crower sell the stroker kit if its a bad idea to do it.
ALWAYS remember that.
that is NOT a reason to buy from him lol. ill guarantee its not a stroked motor in the falken car. probably only uses his cams.Metal4Life..95s14 wrote:gotcha
they're even a sponsor for falken s14
+1Carl H wrote:lol.stroking an already stroked engine is a bad idea.
do you understand the principals of a rod stroke ratio and piston speeds?Griller07 wrote:the stroker kit isn't a bad idea. In the end, thats more horsepower your car will be able to handle without breakin
and overstroking an engine will only lead to shortened life and decreased reliability.Carl H wrote:lol, then dont take offence to this but do some reading/research before you reccomend a stroker kit again.the ka already has close to an ideal rod ratio but stroking it only causes the potential for block explosion due to the increased stresses.also stroking refers to changing the length of the rod throw, not the piston bore.
