Benjammin »
https://forums.nicoclub.com/benjammin-u211034.html
Sun Oct 28, 2012 5:50 am
Im desperate for some help with my z, im having multiple issues after doing an engine rebuild and im not really sure what could be the problem so any help would be greatly appreciated. Ok so about a year ago an injector went out and was causing it to sputter, so after replacing it i ran it for half an hour then shut it off and when i tried to start it again it seemed locked up. Turns out something happened when changing the injector causing fuel to leak and hydro locking the engine and bent a rod. I decided to rebuild so i bought a aftermarket rebuild kit with rings, std bearings, and gaskets. I sent the heads the crank and the pistons with rods to a machine shop and had everything tested and the heads were ported polished and shaved, the machinist said everything was good so i assembled the engine and put it in the car. I also made some modifications like headers, a luk performance clutch, i did an egr delete, tb coolant removal and removed the catalytic converters and because i wasn't replacing the injectors i sent them to be ultrasonic cleaned. When i first started it everything seemed ok, good oil pressure, firing on all 6, but the injectors were ticking louder than normal and it had a knock from the top end. Now since ive done the rebuild ive put about 50 miles on it and ive already had to replace 2 of the injectors. Ive changed the oil 3 times now running valvoline vr1 10w 30. It still knocks but only after its warm and its not very loud at idle only past 2k rpms. On top of that its only getting around 5 miles to the the gallon. Ive checked almost everything i can think of so if anybody could help i woukd really appreciate it. Thanks
