Trun57It's OK! Don't get upset!
Your info was correct, but when you have the luxury of hoists, car stands get left in the corner.
I use 4, 2 ton stands every day. Where there is no hoist, you must use proper stands, & at the worse, use blocks of Hard wood. NEVER & I repeat NEVER use any type of rock, brick cement, etc to prop the car, as they may crack & let the car fall.
Also never trust Hydraulics, as they can give way without warning. I've had 2 jacks fail now, & one minute they all look fine then suddenly the car is on the ground.
The only time I don't use car stands, is when I'm not getting under the car. eg changing a tire or brake pads. (is still a good idea to use a stand)
I have never had a car stand fail in the last 22 years of mechanics, but we have had technicians KILLED (in Australia) by failing car hoists! They're supposed to have Anti-Fall devices built in, but if you don't service the hoist properly, those safety devices can fail as well.
BTW, I also do the Rack Boots the same way as you, but I use Vernier Calipers to accurately measure the position of the tie rod. I then check the toe in with a tape, or adjuster rod as suggested by Nissan, & I find that no adjustment is necessary in most cases.
So ends the safety lesson.
