apossiblehybrid wrote:.....my question is do you guys think i should rebuilt them all or just rebuild that one injector? will the other injectors last for a while? thanks.
I've had my Q for two and a half years, bought it with 120,000 miles and have had to replace three injectors, one at a time. I one-upped the Infiniti gods again though since two of them were #1 and #8 and plenum removal was not required. I've only had to partially remove it once for that 3rd injector. I would say you can expect the same pattern since the nearest non-ethanol gas is a tank and a half drive away.
If you have the bucks then certainly replace all 8 FI and both KS along with every hose under the plenum. It will set you back a few grand but you'll be good for another 100,000 miles. If money's tight the plenum can be partially removed and shifted a couple inches out of the way to get to the #6 injector.
If you know your Q spent it's first 88,000 miles in the Bay Area I'll bet you're under plenum hoses (and leather seats) are still in great shape and very supple. The 94 I parted out was from SF and the under the hood plastic and rubber was in really nice shape. Cool weather makes a big difference.
I haven't checked my injectors for a while but I think I have another one going bad.
