94_240sx vert pics
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Looks awesome!
If you can, try and get a removal/installation procedure to!!!
vert4ya
This has got to be the cleanest, most well put together 240 i have ever seen. Everything is just so simple and clean. i am one to believe that quality not quantity always comes out on top. This car no matter how big or small the mod is just put in the right place. I hope that one day i will be able to say the same for my vert. thanks man
94_240sx
Car: 94_240SX
S13xCrazy wrote:Looks awesome!
Yup!! I took a lot of pictures when I removed it last night. It took hours when I first removed a quarter window assembly, and last night it took only 15 min!!!
94_240sx
Car: 94_240SX
vert4ya wrote:This has got to be the cleanest, most well put together 240 i have ever seen. Everything is just so simple and clean. i am one to believe that quality not quantity always comes out on top. This car no matter how big or small the mod is just put in the right place. I hope that one day i will be able to say the same for my vert. thanks man
Thanks for your kind words. Yes, that's my philosophy too.
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
What did you do about the hand brake?
Sure is nice stopping with the bigger brakes, isn't it?
BMAR240SX
Car: 1993 Nissan 240S Coupe
What rotors are those? There huge
94_240sx
Car: 94_240SX
DeXteR wrote:What did you do about the hand brake?
It's z32 e-brake setup bolt on to the s13 rear knuckle.
BMAR240SX
You drilled them to be 4lug?
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
Dude your car is too sexy. Cut it out!!
Topless_92
Car: 92 Nissan 240sx Convertible
Can't get over how clean this car is. Just keeps getting better. I like those beast rotors and calipers up in there
94_240sx
Car: 94_240SX
BMAR240SX wrote:You drilled them to be 4lug?
Yes, I took them to a machine shop that had CNC Machine equipped with 4-lug drilling program setup, but still holes were like 1mm off, so I had to use a Dremel to make the rotors fit just like OEM ones. I was frustrated when I found out holes were bit off, but everything turned out just fine.
I'll do a full write up on this brake swap with lots of pics. I did over 100mph on the highway, and initial bite was amazing. I'm very pleased with overall result.
Modified by 94_240sx at 10:58 AM 11/11/2008
BMAR240SX
You just keep inspiring me more and more
How much were the brakes? and would you know if they fit with reg 240 calipers until 300zx calipers are available
94_240sx
Car: 94_240SX
BMAR240SX wrote:You just keep inspiring me more and more
Well, I've been collecting parts for years. You can buy z32 calipers on eBay. I bought rest of the parts whenever I have some money. No, you can't use 350z rotors with 240 calipers. You must have 30mm z32 calipers(not 26mm) with custom brackets.
BOOMSHAKALAKA
Hey 94 what's your SN? We gotta talk verts sometime.
Ish I need your SN as well.
Silvia_Drift
Car: 1989 Nissan 240sx Coupe
Damn dude, your car is soooo clean. Its like it rolled off the factory floor. Good job with all the mods!
nis-s13
by far the cleanest vert i've seen...
i would give up my car for this car.
EastTN240
Car: '93 S13 Vert
I'm in awe.............that car is amazing! Now I keep lookin at my white one and seeing the bigger picture..........it has a LONG way to go though to look like yours did when you started
94_240sx
Car: 94_240SX
I've worked on my car all day today to fix the quarter window and install Mighty Lift hood dampers from an auto parts store. I was worried about hood damper installation because I have to drill a lot of holes(total 8 of them), but it came out really nice without running into any issues.
Close up picture of ball joint on the fender.
Ball joint on the hood. This piece needs to be modified with Dremel and a cutting wheel. It could look stock OEM setup if I don't have cuts on this part.
Driver's side.
Passenger side.
Engine bay shot.
There's about two inch space between hood prop and the hole when hood is up as you can see. It means my hood goes up more with hood dampers which will give me a little more extra space. Also sturuts don't get compress all the way in when the hood is closed. There's about an inch slack. I checked other cars that came with the dampers from the factory and all of them had about an inch slack. I spent a lot of time measuring the locations that ball joints would go. I'll give you guys exact measurements, so you guys can try too. My only concern is these dampers might go bad just like vert trunk struts. My Sachs trunk struts lasted only for 2 years. Well, I guess I'll just have to replace them when time comes.
My quarter window fix went fine too. It works fine, and I aligned it perfectly. I had a very good with my car today.
Modified by 94_240sx at 7:16 PM 11/23/2008
adrianfromthecastle
Car: 1992 Nissan 240sx
94_240sx wrote:I'll do a full write up on this brake swap with lots of pics. I did over 100mph on the highway, and initial bite was amazing. I'm very pleased with overall result.
wmdavis007
Car: 1992 240SX Convertible
1997 Jeep Wrangler Sahara 4.0L
Looks great! I've always wanted to put hood dampers on my vert. I'll be waiting on your next post giving us the details. Where did you get them and how much did they cost? Nice job!!
94_240sx
Car: 94_240SX
wmdavis007 wrote:Looks great! I've always wanted to put hood dampers on my vert. I'll be waiting on your next post giving us the details. Where did you get them and how much did they cost? Nice job!!
I knew you would want these. I decided to do it after I saw this thread. I think I spent about $60.
zerothread?id=293203
rico05 who did the write up has a stack of washers on this hood hinges, so it won't fit if you follow his write up. Hood ball joint is what need to be mounted differently.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
BOOMSHAKALAKA wrote:Hey 94 what's your SN? We gotta talk verts sometime.
I don't use chat apps.
Nice brakes, 94.
94_240sx
Car: 94_240SX
Quote »I don't use chat apps.
Nice brakes, 94.[/quote]BOOM, same here. I don't use chat app. Sorry.
Thanks man. How's the move going? Done?
DeXteR
Ish, don't forget us!
Haven't seen you in a while. You'll have to jump back on the vert bandwagon soon.
BOOMSHAKALAKA
ishkabibble wrote:I don't use chat apps.
94_240sx wrote:BOOM, same here. I don't use chat app. Sorry.
It's all good.
How much did the hood dampers cost you? If you don't mind me asking.
And which auto store?
Modified by BOOMSHAKALAKA at 1:20 PM 12/20/2008
94_240sx
Car: 94_240SX
BOOMSHAKALAKA wrote:How much did the hood dampers cost you? If you don't mind me asking.
I think I spent about $60-70. Any auto parts stores should have 4418 dampers, and I got the brackets from Lewis Marine Supply in Florida. I'll measure the spots for the brackets tonight and post.
94_240sx
Car: 94_240SX
I got this idea from http://www.mazda3forums.com and did it over the weekend. Mud guards are not available for Mazda 3, so owners do this. S13 OEM mud guards won't fit on my car because of side skirts, so I fabricated them with a plastic trash can. Came out better than I thought. It took way longer than I thought to cut them, trim, make holes and install.
This is what I used. I bought 2 of them from Office Depot.
Cut like this and trimmed the edges.
Front
Rear. I did both front and back of rear wheel well.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
i love it
94_240sx
Car: 94_240SX
I took some pics this weekend.
At a local Nissan dealership.
With my neighbor's Challenger. 240 looks small.
Coolwhip
Vendor
<3
