blkvrtswp »
https://forums.nicoclub.com/blkvrtswp-u185208.html
Fri Jul 18, 2014 5:52 pm
Fresh swap or working one that just quit?
No fuel is just as bad as too much fuel. Check your oil dipstick for gas small - if present you are flooding the cyls so that is either bad spark or leaking o-ring or stuck injector.
To test injectors, pull the fuel rail with the injectors still in it out of the intake manifold. Leave all the hoses and wires connected. Turn the key on and verify you hear the fuel pump prime (and then shut off after 5 seconds). Look for leaks from injector O-rings - no fuel should be leaking out anywhere.
Now crank the ignition and you should see puffs of fuel coming out of the injectors. All of them at once. If you do, then the basics of the fuel system are working.
Spark is next, pull the coilpack and put a spare plug in it. Ground the threads to the engine head or whatnot. Crank the ignition (whoever is holding the coil pack wear rubber gloves or use a tool with rubber handles or prepare for a really big shock) A nice strong spark arcs bright and snaps loud. Weak spark is caused by poor grounds, damaged coil pack harness or bad coilpack. Ignitor is usually all or nothing.
So if the spark is good, it must be timing. This is where knowing if it is a fresh swap or already running driver comes in. For fresh swap I would google "setting SR20DET timing" and re-stab the CAS. Don't skip over any steps for any reason - if you do, I guarantee that will throw off everything after it.
If it was driving around fine, then try rotating the CAS and simply setting the timing. A little off on timing can amplify any other spark or fuel system weakness.
Good luck!
