im 100% sure this is not itJustin35ll wrote:Make sure you are on TDC of cyl #1 on the compression stroke. You might be on tdc #1 of the exhaust stroke. Make sure it's the compression stroke, then realign the CAS and pop it back in.
Easy way to do it is take out all the plugs but cyl 1. Turn the engine over by hand until it gets hard to turn. Then you know you'll be on the compression storke of #1
It's possible to get the ignitor wired up to where it fires the coil packs 180 out. I've had this happen before. The quick fix solution was to roll the CAS 180 and reinstall until I could get into the wiring to fix the real problem.DrifterProdigy85 wrote:Then your timing isnt 180* out. If the ignitor was wired up wrong, the coilpacks wouldnt get any power to fire the plugs. If you got it started than its getting spark so it shouldnt be the ignitor.
Post up how you wired the ignitor. It's very possible to have read HT's document backwards. I've been meaning to post up a better picture on how to wire it. I've used the HT pinout very successfully in the past.ZOMG.SR20 wrote:the heavythrottle diagram does not work all the wire that is stated in that dont go to the right coilpacks
