IanS »
https://forums.nicoclub.com/ians-u23642.html
Fri Dec 11, 2009 4:14 pm
Brake lines are brake lines. At least on 240SXs. The easiest way to do it, is remove the ABS block as you have, then run new hard lines to each of the front wheels, and the rear metering valve.
