PMaietta08 »
https://forums.nicoclub.com/pmaietta08-u184070.html
Mon May 09, 2011 6:17 pm
I own a 93 J30 and have been dealing with engine/running problems..
This is a list of problems and steps I have taken..
..Car was having problems with idle dropping dramatically after starting and either "catching" itself and idling back up, or dying and stalling out..still had electrical power and able to start back up although a struggle after stalling
..Car began to hesitate when pressing the accelerator after warm up..
..Hesitation began to get very bad,..engine would die down and almost stall when pressing the accelerator..when car stalled, still had electrical power, but pedal had to be floored for car to start again
..Car began to suddenly stall out in a different way..while driving, then slowing down, car would totally die...no engine "die down" it would just completely cut off..no electrical power whatsoever..no dash lights or ignition key reaction...after sitting and checking tightness of battery terminals, electrical power would come back on and car would start fine...
...One time after car stalled suddenly when pulling out, ( no engine die down ..just cut off and no elecrtical power ) I checked terminals again and noticed that there is a red plastic connector connected to the postitive battery cable terminal..it seemed loose and sild off its metal L shaped pin which is connectd to the positive battery cable terminal..( I dont know if its supposed to come off of this pin or if it is broken inside ) when I slid it back on, the electrical power came back on and was able to start the car..
I began to research all the problems I was having with the car and found out a few things..1) alot of people with aging J30s have experienced very similar problems..2) there are like a hundred things in these cars that could cause these problems but the most likely culprit is a faulty camshaft position sensor or dirty/faulty mass airflow sensor
...I pulled the ECU codes ( after being advised to..and taught how to ) and it read a code 13 for faulty coolant temperature sensor..
..I ordered a coolant temperature sensor and a camshaft position sensor..( these are normally between 250 and 350 dollars but I found one on line for 150 dollars )
..I replaced the temperature sensor and the camshaft position sensor..( I lined up the spindle the same way the old one was lined but the new one seemed to go on hard and tight ) ..I also cleaned the throttle bodies and mass airflow sensor ( using throttle body cleaner and mass airflow sensor cleaner ) and replaced the air filter
..the car would crank but would not fire and start..tried over and over again for two days
..I removed the new camshaft position sensor, which was tight and hard to get back out..then re-installed the old one, which slipped right on very easily..
..the car started right up..( I was now wondering if the reason I got the new camshaft position senor for only 150 dollars might be that it is faulty or defective and someone had already bought and returned it )
..now car starts fine, idles fine, revs fine when pressing the accelerator..I thought I had fixed it so I took it for a short spin..ran fine, accelerated with no problem or hesitiation..then just before pulling into our parking space..it suddelnly cut off completely..no electrical power..I pulled the little red connector at the positive battery cable terminal off its pin and put it back on..electrical power came back on and car started fine..
..I thought maybe it was just coming loose from the cars vibration so while the car was running I wiggled it and pulled it off its pin..but car kept running
..so for now I have fixed the problem ( at least it seems like it ) with eratic idling and hestitation/engine die down/stalling when pressing the accelorator..but I need to know if anyone can tell me why it might be suddenly cutting off with no electrical power after driving then slowing down, what the little red connector is, where it leads,and what it could have to do with this problem..could it be something to do with pressing the brakes? ..any suggestions would be apreciated..Thanks and sorry so long
