No corrosion or any visible signs of damage.t.mcginley.jr wrote:For the vibration and noises from under the seats, your transmission mount might be shot/gone. Could also be the exhaust banging around if the hangers are loose/broken.
And what do you mean the MAF "looks" good?
Thanks for the advice. As far as the Tps goes, it's been unconnected and put back twice since i've had it. Once to look at it, the other to clean with the electrical cleaner. I doubt that could be it but i'll take a look.nissanfreak12 wrote:Center carrier bearing. This will give a vibration about 35 and will cause all the issues stated. They are expensive and most change to a one piece driveshaft.
Number three, check ecu for codes. Just because the light on the dash doesn't come on, doesn't mean the ecu doesn't have a code. Also make sure you plugged in the TPS in correctly. The plug that goes into the front of the TPS can get turned around, causing the issues as well. Something to look at.
What do you mean like buy a new maf? and how would i go about checking for vacuum leaks? Sorry, i'm still learning, lolt.mcginley.jr wrote:If its loose then you DO need the 1 piece one, if not the that's not your issue but a 1 piece DS still wouldn't be a bad idea anyway. Have you tried another known good MAF yet? And are you sure you don't just have a bad vacuum leak anywhere?
I have not yet, assuming it wouldn't be anything serious though, no check engine light on.nissanfreak12 wrote:Have you the ecu for codes?
Checking vacuum leaks is just going through and looking at vacuum lines, cracked lines, bad gaskets. Any of them that have cracks, broken, missing, or you hear a hissing sound from them means you have a vacuum leak. It will cause the problems you have. You can do a boost leak tester, yes I know your car is an NA, still works the same way.datsik707 wrote:What do you mean like buy a new maf? and how would i go about checking for vacuum leaks? Sorry, i'm still learning, lolt.mcginley.jr wrote:If its loose then you DO need the 1 piece one, if not the that's not your issue but a 1 piece DS still wouldn't be a bad idea anyway. Have you tried another known good MAF yet? And are you sure you don't just have a bad vacuum leak anywhere?
Is there a different device that does the same thing? Trying to see if someone might have one i can use. I guess i need to read up on how it tells you if there is a leak and how to use it. lolt.mcginley.jr wrote:You can pick up a boost leak tester for $26 I think from Z1? All you need to use it is an air compressor
NOOOOOO!!!! Codes first, then boost leak, lol.t.mcginley.jr wrote:Best bet is to do the boost leak test, you will be able to hear if you have a leak somewhere
Nice!datsik707 wrote:1 Piece shaft came in from z1 today so i got that in. No more vibrations!!. Got some proper wheels too and their balanced. Rides sweet. No codes today though, I'll throw them up when i get them here this weekend. : ))))
