Any thoughts on the Colt cams that PDM sells?InsanityInc wrote:problem is there really aren't any decent cams for the KA NA. I think the problem is the cam makers are used to making a cam for a shorter stroke engine and thus don't consider that the intake close needs to be later for the longer stroke. I'm going to screw with my stock cams one of these days and see what I can get.
Their cams seem pretty meh. It's obvious from their 4AG cams that they know what they're doing, but it just seems they didn't consider the wackiness of the KA when making the cams. It's a pretty unconventional engine as far as high RPM tuning goes, so it's going to need an unconventional grind. I'm thinking it needs a much later intake closing point than would normally be required for any given RPM level due to the long stroke and small bore creating a high velocity slower fill situation, so it can pack more in if you give it time, but if you don't it's going to suffer greatly. I think there might be a place with a dyno very near to me, so I might be able to do some extensive testing pretty soon.BadMojo wrote:Any thoughts on the Colt cams that PDM sells?
I originally thought that the subject of the thread was a mere statement of fact, rather than a question or problem.
"The KA lacks top end power"
"Yes, yes it does. It also sounds like a de-tuned chainsaw motor. Next question, please."
Colt's website says they do custom jobs. Might be worthwhile depending on what your dyno time shows. I'd love to see more options for the NA KA. Gotta be some way to wring more power out of that boat anchor under my hood.InsanityInc wrote:I think there might be a place with a dyno very near to me, so I might be able to do some extensive testing pretty soon.
Dynos don't lie, and I'm not impressed. Note how the power is still dead long before redline. Most of the gains are between 5500 and 6200rpm. Look at the torque curve as well. It's a marginal gain. Also, as far as being regrinds and passing emissions goes: that's all well and good, but also completely irrelevant to the topic of improving the power of the engine. When a cam upgrade produces less power than a catback upgrade, it can be done better.NateDogg wrote:Hey InsanityInc..
Have you ridden in Don's car ? (PDM-Racing)..
I have. Maybe you shouldnt shoot your mouth off about products you have no experience with?
There is no 'lack of high rpm power' in that ride..let me tell you!
Well, if you're going to use it for circle track racing, the best plan would probably be to alter the transmission gearing (or final drive I guess) to try and get your powerband in line with your maximum grip speed. That would probably be the cheapest way to get the desired results I think. At least without some kind of crazy cam.racer33 wrote:Somehow I was afraid this would be the answer. I'm actually planning to set this car up for circle track racing. I can completely remove the exhaust if that will help (all the way to running a bare manifold). I really don't want to spend a ton of $$$ trying to stretch out 5-6hp though. I do appreciate the ideas on gapping the plugs and setting valve lash. Any other thoughts? I used to race an '83 200sx and wanted to do another one, but I can't find any.
Mike
Well you can do a bunch of things to increase more power in the High End.Larger TB's in 65mm or 70mm help with flow numbers in high end.Chopping the intake runners in half will improve high end for 16valve KA's.Moving the MAF and filter 6" to the TB will increase high end.Better ignition like MSD SCI, blaster coil 2.Advance your timing 3 or 4 degress at the distributor.Better aggressive cams PDM or Jim wolfe.Larger high flow cat, and exhaust.Removal of the 91-93 KA butterfly's.Coolant bypass.Performance headers recomended in 4-2-1 Hot shot/DC Sports/Thorley/OBXBelieve it or not even an aluminum fly wheel will increase aspiration in higher RPM's.I've been told that the largest improvement in high end power will mostly be through ecu reprogramming like a standalone like the AEM EMS, or a JWT ecu matched up with an APEXI SAFC. It's mostly air/fuel where the KA lacks greatly and runs more towards the richer side rather than running really lean.Swap to the NISMO 5th gear ratio of .838, or just pull the .838 ratio gear out of a wrecked 97 frontier truck, makes 5th a little more jumpy in the high end.If you want some boostable numbers camden super charging can build an eaton blower for the KAE's and KADE'sracer33 wrote:I just bought this car, and the engine was rebuilt about two years ago. Mechanically it seems fine, but it doesn't have the oomph at upper RPM's that I expect. I have had other 12-valve 240's before that seemed stronger then this. Can anyone point me in the right direction to start? Fuel Filter? Catalytic Converter? Air filter is very clean, plugs are NGK and almost new. Thanks for the help.
Mike
No, it won't. The 60mm TB already has a CFM rating FAR above the power anyone has attained on an NA KA.Bigvinnie wrote:Well you can do a bunch of things to increase more power in the High End.Larger TB's in 65mm or 70mm help with flow numbers in high end.
Once the throttle body is opened any variation in manifold pressure can be measured at the air filter. It essentially becomes part of the manifold, and the length of the intake determines particulates to pulse tuning parameters.InsanityInc wrote:Nope. Anything you do before the TB won't affect your power anywhere. All helmholtz reversion occurs inside the manifold. All this will do is increase throttle response.
I like the way you stated that fact. Big Pimpin. I won't even begin to argue with any one in this forum, believe what you will felaz.Nismo_Freak wrote:
If you have the ability to get an SR gearbox you can get the faster 5th gear ratio from it. It is the same family (w71c) gearbox as the KA's and bolts onto the front bellhousing.
Of course variation in manifold vacuum can be measured there, you're sucking air through it. However, air doesn't resonate through the intake pipe, or else vacuum measured there would have an obvious rhythmic fluctuation. Air never travels back through the intake pipe. The only effect it would have on helmholtz resonance would be the part of the equation put in for plenum size, since it basically becomes a plenum extension when you're at WOT. Therefore having a larger diameter pipe would help the same as having a bigger plenum, and hurt the same way as well.Nismo_Freak wrote:Once the throttle body is opened any variation in manifold pressure can be measured at the air filter. It essentially becomes part of the manifold, and the length of the intake determines particulates to pulse tuning parameters.
Yeah the only problem I find with the NAPSZ using the DE head is that you have to fabricate the napsz front covers and sump for de use. Who can make a front assembly for me Devious KA? I'm not inclined nore do I have the tools required to fab it my self, the sohc is much easier to frankenstien onto the Z blocks. Any info would be great I'm trying to do a DE swap onto the z block for a high rev boosted 510 project.deviousKA wrote:This is one of the reasons i only use de heads on 2.0-2.2l. They are a great head overall for that purpose aside from the exhaust port angle.
