Hey Vinnie, I missed that post you made about the front cover/timing configuration.
There are a few ways to go about doing this, depending on what your starting with. Your looking at less fabrication and and overall cleaner setup by starting with either a frontier, or an altima ka24de head. These lack the upper cover mounted distributor and have a slimmer design in that dept (closer fit to sohc style cover). A small amount of fabrication is still necessary, on mine i modify the covers by building up the edge with multiple beads of weld and get it re-decked, then drill&tap. It all gets cleaned up afterwords of course.
As far as the actual timing chain components your going to need a few custom items as well. The lower single chain you will need to get a custom length, mercedes master and half links come in handy if your modifying an existing chain, if you go with performance oriented chain (Renold, Iwis, rollmaster (iwis), tsubakimoto) you should get master and/or half links from same manufacture. The size is 06 british standard. My personal favorite is tsubakimoto, which is only available direct from japan in 20ft or longer rolls. IWIS is german and only available direct from manufacture in rolls as well, although there are a few retailers in austrailia that you could contact and see if they will sell in unbound length (rollmaster, rolmac).
You will need a custom fit lower gear for the ka tooth count on the l/z crank snout diameter. I get batches of these made up from time to time, dont have any extras at the moment though. Im not going to divulge the information on how i do this publicly, if you want to know you can email me
[email protected] .
With a few slight adjustments of the original Z style timing guides everything goes together quite nicely. Original style hydraulic tensioners can be used, but on mine i use adjustable Malvern-Racing tensioners which are no longer made. Kameari may make adjustable Z style tensioners but you would have to contact them to find out as they arent listed in their catalog.
I dont make up full bolt on assemblies to sell, but i do complete longblocks on request. Might arrange some various hybrid kits in the future once i get some of this casting/mold work done, but will all be tailored to NA/race use.
