elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Jan 16, 2007 9:07 am
Ive removed a door panel a million times on a Q.... SLide the armrest back (I get a thin putty knife and slide it in there, screwdrivers will make marks), and it will not want to move but it will eventually. Will expose 3 screws...
Then pull the trim piece off with the door switch. best way to get the trim peice off is to take a screwdriver, pry the front part and it will unsnap, then you can massage it out with your fingers.... once you have it massaged out, you pull it foreward and itll be free and not broken.... Thers one more screw where the grab handle is.
Then its just clipped in, start at the bottom and work your way up. once you have done that, lift up and undo the harnesses.
