If his head is within the factory spec, it'll be fine for those power goals. Will it run better if he gets other stuff done to the head, of course, but its not necessary. At that power level, the way to avoid detonation is to get a proper tune and make sure the fuel system is perfect.asoomal wrote:
Well, getting a full head work done will reduce the chances of detonation and make it run smoother. If all the combustion chamber are within the same spec, as in if they all are the same size, it will definitely run smoother. Not to mention it'll increase efficiency, more power with less boost, using less gas.
Also, all the cylinders will be producing pretty much the same amount of power, making it last longer and increasing power again.
