FINALLLYY FIXEDD!! ,
step 1 : found the yellow/red stripe wire on the back of the cluster
step 2 : found the yellow/red stripe wire on the ECU
step 3 : spliced the outer plastic on the wire and just attached the other wire i didnt cut it, cuz it didnt seem like i need to
since its all working now but i didnt wanna cut it and something else wouldnt work so i did that and the rpm gauge works perfectly and after i finished red lineing the car sounds goood
! . thanks for the help guys !
also i the gas meter suppose to stay on were ur gas is when the cars off? or cuz mine just stays up on half tank well thats were i filled it and seems to be at and goes down while driveing x) so yea.
