lebgangstah »
https://forums.nicoclub.com/lebgangstah-u194495.html
Mon Dec 05, 2011 10:38 pm
also , u can cut the wire and just rewire it if ud like what u said is correct , me i just didnt want to , cut it so i basicly , spliced the wire and attached the other ( ripped the outer layer off in the middle of the , yellow wire/ red stripe , on the both the ecu and cluster harness , and connected the new wire , tryed it first! then tapped it , all worked well , compactfean said that u can cut it wich is also fine aswell i just felt i didnt need to since it worked with no probloms .
