LOL. Also replace pedal and pedal pad. Also shifter and shift knob. Just start throwing parts at it.1sikS13 wrote:first off the search buton comes in handy on a topic like this. USE IT! tHIS WILL BE YOUR FREEBEE replace the clutch master and slave cylinder bleed clutch problem solved
Slave cylinder. I just replaced mine last weekEntity240 wrote:I don't quite know what's going on with my car. All was well yesturday and then today, all the sudden, the clutch peddle keeps sticking to the floor and sometimes doesn't let me go into gear or come out of gear. It just happened out of nowhere. I pushed the peddle to the floor and the pressure felt weak but it went into gear that time just fine. But then, The peddle just stayed stuck to the floor. And then, when I tried to pull it out of gear, it wouldn't let me.
The clutch itself is fine, there's no way in hell it's going out cause I never race it or anything like that. Plus, my revs don't go up as if it's slipping when I give it gas in gear. It has to be something with the pressure or peddle or hell, I don't flippin know.
Help!?
just read ur thread, my old 240 did exactly what u described to a T, once. and then it was fine from then on outwackawacka wrote:Visit my "clutch problems" thread and be....amazed? Truely mysterious.
zerothread/299644
thats exactly what mine did when teh slave cylinder was badEntity240 wrote:Cool. I'll try the slave cylinder.
It still goes into gear but I have the pump the clutch a **** load and then use my foot to bring it back off the floor.
We'll see if that helps any.
be sure to bleed it.Entity240 wrote:Cool. I'll try the slave cylinder.
cuz nissans trannies area little on teh weak side. the nx will have 5th gear completely die (its a definite that it'll die and i've experienced it) the SE-R sentras have transmission problems w/ 5th iirc and 240s have weak clave cylinders and 2nd gear grindcman6146 wrote:So why does this seem like a common problem with the 240s?
not entirely true, it is most commonly the synchros but depending on how/ when it grinds it could be the gears themselves of teh fork as wellDougRoost wrote:
As for "grinds", that means your synchronizer(s) are worn out. This happens from people abusing any manual transmission (e.g.- powershifts). The synchros are the first thing to wear out in any manual transmission, regardless of manufacturer. You can do as White Comet suggested and find a used one and hope it's not been abused, but the problem is it could fail 3 months later. The more expensive choice is to have yours rebuilt and know it'll be good as new. Depends on your budget and plans for the car.
